cudase
Does anyone sell a allen key shoulder screw for the 05-07 body style vector. The phillips head screws leave a lot to be desired
The philips screws work if you use a #3 screwdriver
new4stroker
Vectornut
- Nov 18, 2007
- Eden, Vermont
- RS Vector
In your RS tool kit there is in there the correct phillips screw driver for that purpose.
TOMBOB
- Jan 20, 2011
- Saranac,Michigan.
- 2006 APEX ER
CUDASE
take your 3 bottom screw out,take then to wire
buffer reomve the paint. attach #6 nut over the
screw. use j-b weld hold it in place. to do this use a small c-clamp when you glue then together
let then dry for a day. put coat paint on them. trick to this is get the nut centered over the screw.
do three at a time.
TOMBOB
do three at a time.
TOMBOB
Handy
- May 12, 2005
- Anola Manitoba
- 1983 Bravo, 1988 XLV, 1991 Pazer II, 2005 Vector, 2006 Apex Super Charged, 2017 Viper STX DX 137, 2018 SR Venture DX
Go to Yamaha & buy the 07 Phazer top panel screws. They have the same thread with a 10mm hex so you can use a socket.
