Vector body panel screws
cudase
West Michigan
Does anyone sell a allen key shoulder screw for the 05-07 body style vector. The phillips head screws leave a lot to be desired
In your RS tool kit there is in there the correct phillips screw driver for that purpose.
CUDASE
take your 3 bottom screw out,take then to wire
buffer reomve the paint. attach #6 nut over the
screw. use j-b weld hold it in place. to do this use a small c-clamp when you glue then together
let then dry for a day. put coat paint on them. trick to this is get the nut centered over the screw.
do three at a time.
TOMBOB
Go to Yamaha & buy the 07 Phazer top panel screws. They have the same thread with a 10mm hex so you can use a socket.
