Vector ltx plastic cargo rack part #
  • Thread starter Thread starter Anonymous
  • Start date Start date
A
Anonymous
I saw a Yamaha long track 136" sled with a plastic cargo rack.There is one on ebay # 260556293486. The rack had plastic side pieces and a rear piece. The rack was aprox 6" tall. This acessory was moreless a filler for the aluminum track extension. Does anyone have the yamaha part numer or any info?
brian 629 said:
I saw a Yamaha long track 136" sled with a plastic cargo rack. The rack had plastic side pieces and a rear piece. The rack was aprox 6" tall. This acessory was moreless a filler for the aluminum track extension. Does anyone have the yamaha part numer or any info?
If it is a pre 2010 Vector 136" a plastic rack will melt from the exhaust heat unless you install turned out tips. I have a small Powermadd tool box on the rear of my 2009 but it sits low plus I covered it with heat reflective tape.
The 2010 has Apex type exhaust which are wider and higher. May be possible to use larger rack on these.
