Vibration after 30/40 mph????
bleedyamaha
Northern Iowa
2017 Yamaha Sidewinder Rtx Le 2012 Yamaha Vector Ltx
Just took out my 14 Ltx se for a quick spin in 12 inches of powder. After getting on the throttle I am feeling a vibration I have never felt before. The only things I changed from last season is I had my skid shocks revalved and added weight to my Cotc. I did re adjust my osp belt adjuster I backed it out till the secondary just barely started creeping. It feels like you feel every lug on the track when you get on the throttle. I don't think the track is spinning but the snow is real powdery. I will check for track rub when the snow melts under neath further.
I put my sled on a lift and cranked on the throttle and didn't feel any vibration.
Stingray is probably right. The slides thing was something I noticed last time I put new ones on. So if yours are still good. Run them.
I would also go with the belt. If you had the sled running and reved it a lot the primary will groove the belt in one spot and vibrate almost feel like the track is coming apart.
Thanks guys put on 30 miles this a.m. Will try the belt next trip out. My exhaust can tail pipe broke loose this morning. Arhhhggg!
I had a vibration like you mentioned last season and it was the belt!! It was felt at my feet!
