174alltheway
- Feb 16, 2009
In the service manual for the viper it says to bleed the coolant through the bleed screw.... I can't find a bleed screw anywhere??
- Apr 14, 2003
- Hessel, Michigan
Hmmmm, I looked thru the microfiche and don't see a bleed screw.
Worked on a few Vipers now and just fill with coolant, everything worked good.
stingray719
Just make sure to heat cycle a few times before you lean on it hard, needs to cycle the air out.
174alltheway
- Feb 16, 2009
Ya I couldn't find one.....I have all the air out I'm confident in that but when I stop for a few minutes and restart its hot, real hot. I'll have to check the coolant strength I guess don't know what else it could be
- Apr 14, 2003
- Hessel, Michigan
Hmmmm, watch your temp numbers. Fan should kick on mid 190's - 200's. If it's circulating....the fan will start to bring numbers down.
With the sled warm and the cap on (don't remove the cap when hot), pick up on the front right ski to get bubbles towards the cap.
stingray719
What would be the exact numbers on real hot?
174alltheway
- Feb 16, 2009
I've positioned the sled in multiple positions eliminating air..... It's fine when the sleds running all is normal, when shut off for a few minutes it starts to boil you can hear it, when started up I've seen 238 but they only stay high for a couple seconds until it circulateds fora couple seconds then it's all good
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
That sounds normal for temp to go up after shutdown. Keep an eye on it when you ride but I think it's good. You should hear and see it in the summer when it's 90* out running asphalt. If restarted soon after a run its hot for a couple second until it circulates then it's ok. Sounds ok to me. Just watch it.I've positioned the sled in multiple positions eliminating air..... It's fine when the sleds running all is normal, when shut off for a few minutes it starts to boil you can hear it, when started up I've seen 238 but they only stay high for a couple seconds until it circulateds fora couple seconds then it's all good
