viper diet....
yes I am back to the stock battery,
The li-ion batteries do not have enough initial jam to over come the compression of my motor even with the battery warm..... If the battery is at all weak while cranking the motor over it will strip out the teeth on the starter gear. So far I have had to pull the engine twice because the battery didn't have enough jam to push the starter through the compression stroke and it kicked back stripping the teeth. it was two very labour intensive lessons and a few parts later. Not really sure where I wanna go from here. There is not enough room in the nose of the machine to put the YTX20LBS. I am hesitant to go to a YTX14 or 16 because I know the 20 works.
I do however have one more full set up for the starter gear assy..... do I go to a lower cranking battery to save weight? or carry a AMP booster pack for the first start up in the morning running a YTX14.....
I hear you :) Is this an issue for your engine or would it be same issue for a stock engine?
I guess the weight saving will need to come elsewhere? ;)
Birkebeiner
This is just a problem because the stroker kit has raised my compression in my motor
I still think there has to be a amperage drop with the long battery cables we all have. I have some welding cable that I may experiment with. That said can you run your exhaust valve to the tight side of clearance? Even a little would help the decomp.
Personally I would go with Nology for coils. Using a wire gets the coil out of engine heat.
Started to install the 2016 front suspension on my viper with a 38" stance
began to pull side panels and hood off
next came skis and exit shocks skid plate and belly pan also came off
pulled off the upper, lower arms with spindle all attached
you can see how much a difference these arms could make
left side is put together loosely
AND COMPLICATIONS FROM HERE ON OUT......
the exit shocks have to big of a rez and the top a-arms is not even close to fitting!
I then flipped the shock over to see if it would fit...... not so lucky, the spring closest to the top shock mount hit the plastic pan, too much to heat it up or change its shape.
took the right shock and put it on the left side to see if the bottle would clear .........and it did!!!
as you can see above the top a-arm ball joint has been back along way out to get the top a-arm bolt holes to line up.
when the sled is off the ground the tie rod will clear the bottom a-arm until I turn the bars to the left and it almost instantly hits the bottom arm.... when I turn it to the right there is a lot of room for the tie rod to move.....
not sure were I went wrong here, since the shock should be the same length as the 2016. Going to take another look over the machine later this week.... I changed the suspension back over to my 38" front end last night so I could bring it into the dealership if I am not able make it work. It is always good to get a second set of eyes
I just did this conversion on mine. Went from the 38" to the new 36". I have the fox evols on mine and the 38" kit shocks needed to be shortened so I just bought the shocks for the 36" as they are a bit shorter.
I had the same problem as you in this regards. The left side a arm hits the a arm on full turn. The right side did not. I think the left spindle is slightly off from the mold or something. So it is not just you. Just great arctic cat quality control. You will need to shim the ball joint to get it to lift off the a arm.
That was going to be my plan put a extra washer under the tie rod end to lift it up a bit. When I spoke to the guys the 38" front end shocks were expected to work with the 36" front end.
when the front of the machine is off the ground and the suspension is at full travel the tie rod does not hit, it is only when I turn the bars to the left it hits.
yeah I cant give up these exit x2 shocks. Maybe this front end kit is gonna be a bust
Read through you thread, like all the work you've put into the sled, with the auto tune, did you use the stock exhaust bung or do you need to install a new one and if so we're do you place it?
Cheers,
Chris
send the shocks to exit to get em shortened.
Have you thought about trying some super caps. Big capacitors will deliver lots of juice all at once and may aid a week battery.
