sk-rx1
Arctic Cat has a Sport Bumper for ZR7000 and others, not as cool as the accessory bumper but it lists for less than $100. Country Cat website, or ebay, has them for $76, plus shipping. If that's what you were asking. The 2-3 hundred dollar bumpers are a bit much for me.
I went and looked at a black viper last night at my dealer. I have to agree on fit and finish. You happen to notice the gap in body panels on exhaust side behind shock mount?? Whats up with that?? At least there was one on this one. Also tried taking panels off and thought what a pain in the #*$&@. They didnt have setup so couldnt here run but other than that pretty cool sled. There was a left over vector next to it and you defintely notice the difference in fit and finish. At same time look at the purpose of viper. More of a rough trail boondocking sled thats probably gonna get thrashed around a bit. Where as vector is like taking your caddy out. Dont want no scratches. Just a thought as to type of material used. Still on fence about one. I figured id see it and be sign me up!!! but wasnt. Thinking I might still look at another brand. Or at least wait till he gets a red one in.
Yup if your not in a hurry wait and see how this new platform performs.
Update 12-5-13 on page 1
12-5 update
Well it snowed,rained and snowed again yesterday and we ended up with about 6-8" Took the viper out for the first time and it was in the ditch. Power felt great feels just as fast as my old Nytro and seems to be on par with my Apex but not sure since I have not ridden the Apex since last season. I rode my phazer for about 20 miles before I took out the Viper. For those of you who are going from a phazer to a viper HOLD ON! It will rip your arms off! lol.
Bumps and jumps.
It defiantly does not jump like my phazer but it is night and day difference from my APex. Compared to the Nytro it didn't feel as top heavy and more planted. The chassis is extremely rigid on some med to bigger bumps it wanted to buck me off and landed solid. I check the air in the front shocks tonight and one was at 90 and the other at 75. I set them both to 70 and took it out for about 5 miles and it was like a new machine. Ate the bumps and didn't feel like it wanted to buck me off and just felt more stable. So check you air pressure!
Clutch.
As always it a awesome Yami clutch it engages instant, even when your coasting around a corner and you just slightly touch the throttle for a tiny bit of speed it engages off you go.
Brake.
Felt great on in the ditch didn't take much effort to lock the track up when applied hard. I did get on it a bit in a field and tried to stop as fast as I can from about 80mph threshold braking and not locking up the track about three times. Compared to the Apex, phazer, and Nytro brakes it was good. not bad but not as good. Had to apply a bit more pressure on the lever and you could just feel that the pad and rotor didn't bit the same. Too much pressure and the track would lock not enough and it didn't want to stop as fast. I'm sure this is from the design and that the rotor smaller than the phazer,nytro, and apex so their is not as much surface area. But overall good.
Most of the riding was done in a ditch. I have yet to test it on a trail, but from what I can tell already I think this machine will carve the trails like a hot knife through butter!
Dang. What do you mean it doesnt jump like the Phazer?
So you use 1 or 2 fingers on the brake of your Phazer and Nytro? How many are needed on your Viper?
YamahaTim
- Sep 21, 2013
- Farmington, MN
- 2014 Yamaha Viper LTX SE MPI Turbo
Don't worry cannondale27 I seen him jump first hand, it ain't pretty...lol just kidding apexgt40 just have to break it in first so that you can jump using the throttle. Not just rolling over the jump....lmao. The Viper will fly nicely I think once you just get used to it and commit.
YamaHank
- Apr 1, 2013
- Boston, MA
- 2018 SR Viper RTX
You guys need to watch the videos on Yamaha's Facebook page...they have clips of the viper soaring through the airYamahaTim said:Don't worry cannondale27 I seen him jump first hand, it ain't pretty...lol just kidding apexgt40 just have to break it in first so that you can jump using the throttle. Not just rolling over the jump....lmao. The Viper will fly nicely I think once you just get used to it and commit.
They jump nytros high too. I have also and it sucks. Much easier on Phazer.
Phaser should be easier it looks like a cricket
Sorry just had to say it!!!!!!
YamahaTim
- Sep 21, 2013
- Farmington, MN
I have had the Nytro pretty high up. I know the Viper will do that. Yes I did see those videos. Awesome! Should have mine up and running Tuesday so I'll find out.
The difference on the brake is going to be the direct braking. All the normal yamaha sleds brake of the Jack, giving the brake, almost 2-1 mechanical advantage. Being on the drive shaft adds some advantage but also gives some issues, as in, you can not increase the size to compensate for the loss of gear advantage because of the belly pan restraint, and ground clearance. an advantage is, if you blow the case, you still have brakes.
Thats true but I got directly off my Phazer and right onto a 6000 ElTigre last winter and the brake felt the same or better than my Phazer where in all previous ProCross rides I thought the brakes sucked. So the potential is there. May have to try the Master off a 6000 or do some measurements if possible since on 14 cats they are using a smaller piston in master than the 13's. Was hoping the Viper got the same. Will find out tomorrow when I ride it I guess.
It's not really fair to compare the viper to the phazer when it comes to jumps because of the size difference. but I was riding the phazer just before the viper and I noticed a big difference in just how it felt. When in the air you can feel the mass compared to the small phazer. You could say it doesn't glide as well. When it lands because of the weight you can feel it and just does not land as light. Its more like dropping a bag of rocks lol
Its not a bad thing really unless you have both sleds and are out jumping. If you never ride a phazer and learn to jump on a viper you will be just fine.
At higher speeds I was using two fingers on the brake. Biggest difference was not being able to threshold brake as well at higher speeds even compared to my LTX apex.
Again this is just comparing it to the others but their is nothing wrong with the vipers brakes.
cannondale27 said:Thats true but I got directly off my Phazer and right onto a 6000 ElTigre last winter and the brake felt the same or better than my Phazer where in all previous ProCross rides I thought the brakes sucked. So the potential is there. May have to try the Master off a 6000 or do some measurements if possible since on 14 cats they are using a smaller piston in master than the 13's. Was hoping the Viper got the same. Will find out tomorrow when I ride it I guess.
That Cat 7000's are using a 9/16 diameter RMC braking system this year and the Vipers are using the Hayes system. One of the magazines did a comparison between the two sleds and commented that they preferred the feel of the Cat brakes over the Vipers. It's one of they few mechanical differences between the 2 sleds.
caddleman
- Dec 10, 2011
Been a long time 4 stroke sled owner starting with the RX-1. I currently have a Apex, and two Phazers, Viper LTX, and just sold my nytro. I went from skidoo to a Rx-1 in 03 and loved the RX-1 even though it was a tank.
Bought a 08 LTX apex 40th and love the sled. To date it is the best handling sled only down fall is it's weight and I kept getting it stuck in deep snow or in the ditch so I bought a Nytro.
The Nytro is a complete different animal. Lighter, easier to jump and it also ate the bumps and jumps better than the Apex. Only thing I didn't like was the handling. You couldn't hit the apex as fast as the Apex. Other than that the nytro is a great sled.
So I decided to buy another got a Phazer since it was the lightest one of them and I was also trying to get the Miss's into snowmobiling. Well she didn't like it so I rode it! Its stupid light compared to the apex and nytro. It fun as hell to jump and ditch bang. But when the trail gets straight the fun ends.
My style of riding is aggressive and mainly trails as I love to fly through twisty trails. A sled that handled the corners was a must for me. To get to the trail head I can trailer or ride the ditch and have some fun in the fields on the way, and i always choose to ditch since the ditches around my place are very wide and snow is always good. I ended up with one of each model because not one model would suit my needs and that's where the viper will hopefully fill and I can sell the others.
So as a long time Yamaha enthusiast here is my $.02 on the Viper.
I never had the chance to ride one last year but talking to people who did and of course the Yami reps got me curious and now I have a LTX SE.
The seating position feels good plenty of cushion on the seat and the factory bars and risers are just right. I'm 5'8" The machine looks mean as hell the styling is a 10/10 imo. with the first start up it didn't sound like any other four stoke yami because of the front dump exhaust. But its not a bad thing. It sounds mean almost like a SBC with a bigger cam. All of my other sleds have stock exhaust and especially on my Apex you can tell its loud even with my helmet on. So it will be interesting to see how loud this will be with the front dump under load. The muffler is pretty big under the cover.
With only the engine and clutching from Yamaha the only downside is the materials and fit and finish. you can clearly see with this sled. compared side by side to other Yamaha models the materials used on the viper are not the same high grade materials used on the Apex, nytro, and phazer. I'm sure they work just fine but when you're used to the Yamaha quality its kind of a shocker. Best comparison would be to own a brand new 2014 Ram and then hop into a 1995 model with a cheap hard plastic dash. This is only with the plastics for the buttons, and gauge cluster. The side panels feel nice and thick. The front bumper is worthless it is so damn flimsy. I almost already bent it by lifting on it. It looks like a stamped piece of metal and is only secured in four spots. Another big noticeable spot is on the stitching on the rear end of the seat.
Again unlike its siblings the Vipers parking brake is not a solo unit. Other models as you know you flip the lever and the parking brake is engaged. On the viper its the old school pinch and go style. Grab the brake and pull the red tab to hold the brake lever in place. Again the material for the red tab is not the best and imo this could fail if it super cold or if their is build up around the handle and you get rough with it. Also note if you have it set and trailer a long distance or have it engaged for a long time its is wise to pump the brake a few times after it is released as these setups sometimes bleeds the fluid out of the caliper and back into the line/reservoir.
Reverse!
Nothing wrong with the old yami reverse but a few times I had to rock my apex/nytro, phazer to get it to engage. This push button reverse on the Viper is pretty slick. used it a few times off the trailer and around the shop and it engaged effortlessly and right away.
If you are on the fence to purchase one I would say just wait. Its always fun to be the first to have the newest toy but as we all know first year productions always have flaws and following years are always better. I say this because sleds these days are $$ and not a 5k sled like back in the day. That's allot of money to most and you all work hard so you can play hard. That is why this forum exists because we demand the best and that's why we choose Yamaha.
So in the end I give the looks a 10/10. This machine looks pissed off and it's ready to shred the trails. Fit/finish/materials/. I give it a 7/10. It's not like what we are used to on other Yamaha models but it is a first year model and a HUGE change working with AC and having sleds built by AC in MN. Fitment is not bad. body lines are good and no serious gaps or misalignment's. What brings it down from a perfect 10 is materials used and the quality control or engineering on those parts.
Engine/Clutch
Yamaha is a engine company. That is their strong point. They know engines and that's what they are good at. If you don't know Yamaha built the Japanese market Beams engine for the IS200 (is300 in the US) and when Lexus/toyota wanted to build their super car the LF-A it was Yamaha that was commissioned to help build the engine in the half million dollar super car. That's just two examples of engines they built for major auto manufactures but they have built many more. Some of you might remember the old ford Taurus SHO. That motor was also built by Yamaha.
As we all know Yamaha clutch system is the best and the most reliable. I am glad that it was carried on to the Viper. How it is set for the viper is still to be determined, but driving it on and off the trailer and into the shop it engaged right away like other models so i'm sure it will be what we are all used to. Even though it shares the Nytro engine/clutch system, their are differences and a Nytro belt will not fit.
Bottom line.
Since I have not ridden one yet i'm hoping this sled will out perform the Apex and nytro. So until then one can wish. I will update this once the snow flies and I get her broke in. As this new model develops i'm sure Yamaha will continue to improve all aspects of it. I'm sure they will be getting a TON of feedback good and bad and hopefully they listen to their loyal customers.
Pics and vid
Vids
http://smg.photobucket.com/user/Bistro2 ... 6.mp4.html
start up inside and walk around
http://smg.photobucket.com/user/Bistro2 ... 3.mp4.html
12-5 update
Bumps and jumps.
Clutch.
Brake.
I also have an 08 apex LTX gt 40th I am planning to snowcheck a viper ltx with turbo, I am interested in how you had your apex set up and if you are happy with the viper now that you have had it for a while. thanks Cary
