I'm working on a friend's viper with 270hk. We are getting a lot of slipping when doin takeoff. What do we need to do. More spring in secondary or less helix?
The machine has heavy hitter, 911, stock primary rollers, orange primary spring and a 8dn belt. secondary we have tested big venom spring twisted to 60 to 80degree, stock spring twisted to 60-80 degree Dalton red twisted to 60-80 degree. 45 helix.
The clutches don't run hot but hammering gas from beginning the belt is snapping.
Rpm whit stock pink spring is in takeoff 9600 then it falls to 7800 after 1.5second then it climbs to 9000rpm and stays there. If we go wot from 30km/h it goes to 9000 and stays there.
What do we need to do for change? More weight in the middle hole, 14.5rollers? More spring in secondary
