stormin norman
- Dec 11, 2007
- Southern, MN
- 2014 Yamaha Viper LTX LE
2000 Yamaha SRX 700
1999 Yamaha V max 500
1992 Yamaha V max 4
1984 Yamaha Phazer
Has anyone here tried the Viper Quiet Clutch Kits that are for sale on the web? They are small washers that you install on the space between the roller pin and the bolt on primary clutch. Says it will eliminate the clutch rattle noise. has anyone used these? Thanks
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
How much are they, i was able to find some plastic/nylon washers at my local hardware store, 80 cents for six of them, they were the perfect i/d and o/d, definitely a lot quiter.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
People have used them on other 4 stroke yamaha's, they seem to do what they claim for a few hundred miles then start making noise again unless you install new ones. It's just the "start stop" effect of the high compression, low firing 4 stroke that makes the weights hammer back and forth on the pins. I used some nylon washers like Murdered suggested on my Phazer and it did cut the noise down for 1/2 a season, what ever you get/use make sure it doesn't effect the free swing nature of the weights. I haven't done nothing with the Viper yet, the Big Thunder weights don't make nearly as much noise as the stock ones did.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
I believe we were talking about the roller pins, not the washers on the weight sleeve, they make noise too but very minimal compared to the roller pins.
Dusty Dan
- Jan 24, 2015
- 2016 SRViper LTX LE
2012 Vector
I put the kit in my Vector with same engine but did not notice any significant difference. I have a Viper now and will not bother.Has anyone here tried the Viper Quiet Clutch Kits that are for sale on the web? They are small washers that you install on the space between the roller pin and the bolt on primary clutch. Says it will eliminate the clutch rattle noise. has anyone used these? Thanks
09nytro
You can grind the pin down so it’s flush , then tighten the bolt back up!
Works good!
Works good!
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Thought about doing that too, more of a permanent solution as the washers tend to sif2ten and wear with miles.You can grind the pin down so it’s flush , then tighten the bolt back up!
Works good!
