skidoo433
- Oct 3, 2015
- 15 viper XTX, 15 Viper MTX Turbo, 11 nytro xtx turbo, 13 nytro RTX, 15 Poo IQR
- West Bend WI
Hey guys i have a 2015 Viper XTX SE. I am looking into stretching it to a 153. My question is, since it is an SE and not an LE, will i have to have a tunnel extension? I have been trying to search and have not found a straight answer. Also, for the guys that did it, but were all the parts you had to buy? looking to run a 2.25 track as well so will I have to change drivers?
Thank you for any input!
Pretty sure that's what NosPro runs. He just swapped rails. Everything bolted right on. Not sure if he used same drivers though. Maybe try PMing him.
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Same drivers for 2 1/4 track mounted in lower front hole. No tunnel extension.
skidoo433
- Oct 3, 2015
- West Bend WI
What kind of rails are you guys running? And do you need different suspension arms?
shagman
Vendor
- Feb 18, 2014
Stock 153 cat rails. Everything bolts up and keep same mounting locations.
skidoo433
- Oct 3, 2015
- West Bend WI
What year rails are you using?Stock 153 cat rails. Everything bolts up and keep same mounting locations.
shagman
Vendor
- Feb 18, 2014
2013
upei93
- Apr 27, 2008
- Dalhousie, NB
- 2017 Sidewinder BTX Hurricane 270 tune
2015 Viper X-TX LE MPI turbo
The le tunnel is a bit longer then the se...noticed it this winter when I was parked next to my buddies se...we didn't have a tape measure just used a stick to get a rough measurement...not sure if it will matter if you stretch yours or not.
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
2016 Vector LE For my Bride
2007 Phazer GT, 136" Stretch.
2002 SXR600 (still own)
1997 SX600 (sold)
1997 XT500 (sold)
2013 Can-Am Maverick 1000XRS
The center shock is also a bit longer on the 153 skid than the 141. Rear shock is the same. Not sure how much this effects the geometry, but they are different. Buddy is in the process of trying to find out just how different in length they are as he is in the middle of a 153 swap as well.
skidoo433
- Oct 3, 2015
- West Bend WI
basically i am looking to see if the SE tunnel will be sufficient enough for a 153? i know the LE is longer, also want to see if the yamaha 153 rails will work, so i can keep them blue haha. I will have to look into the shock as well.
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
Confirmed, center shock is one inch longer on the 153 rails when compared to the 141 center shock. I believe this due to the front W-arm having a higher mounting point on the 153 rails so they needed to have a longer shock to make up the difference. Rear shock measures the same. I cant wait for snow!
yamahaguy
Ride SAFE
- Apr 20, 2014
Your Correct, the tunnel is longer on at XTX LE. Its actually a MTX Tunnel.
