vk pro no top end
brad gilker
Age
62
haliburton
Canada
vk pro
My 06 VK PRO starts and runs fine but has no top end, feels like it's running at 2/3 power.
Can get more the 60 mph. Cleaned carbs, changed plugs. Any suggestions. 6000 miles on her.
As to the rapid slider wear, I swapped out the original idler wheel for 1/4" larger diameter ones and now have 2000 kms on cheap Gamma sliders
it can affect it. if they are noisy replace them.
I had a 2007 same problem cause was a broken secondary drive clutch spring.
Get clutches checked
But sometimes it goes like an Apex, the falls flat on its face
Some times it goes like an Apex, then falls flat on its face
donuts done. No snow yet. It's for sale. Found a brand new 2016 for $12,500
ok. i was just going to suggest a new primary spring as my et does something similar when the primary spring is shot.
What was your problem? I'm having same issues now with 07 pro, idles good but wont rev past 6000 rpm WOT
