brad gilker
- Feb 14, 2016
- haliburton
- vk pro
My 06 VK PRO starts and runs fine but has no top end, feels like it's running at 2/3 power.
Can get more the 60 mph. Cleaned carbs, changed plugs. Any suggestions. 6000 miles on her.
As to the rapid slider wear, I swapped out the original idler wheel for 1/4" larger diameter ones and now have 2000 kms on cheap Gamma sliders
brad gilker
- Feb 14, 2016
- haliburton
- vk pro
I think my exhaust donuts are pooched. Would that effect top end power?
it can affect it. if they are noisy replace them.
theyammyman
- Mar 22, 2016
- Dryden
- APEX XTX
I had a 2007 same problem cause was a broken secondary drive clutch spring.
Tunepipe
- Oct 5, 2014
- Sormany
- VkPro, Venture TF, Phazer, Snoscoot 200...Sidewinder, Excell III
Get clutches checked
brad gilker
- Feb 14, 2016
- haliburton
- vk pro
But sometimes it goes like an Apex, the falls flat on its faceI had a 2007 same problem cause was a broken secondary drive clutch spring.
Some times it goes like an Apex, then falls flat on its faceI had a 2007 same problem cause was a broken secondary drive clutch spring.
donuts done. No snow yet. It's for sale. Found a brand new 2016 for $12,500it can affect it. if they are noisy replace them.
ok. i was just going to suggest a new primary spring as my et does something similar when the primary spring is shot.
