after freezing my hands last year in my klim gloves doing the abitbi canyon loop, i ended up putting on a set of mec mitts that i carry as spares, i found in their clearance bin for $15.00 and my hands where toasty warm the rest of last season.
this season i have been running a set of outlast single finger snowmobile mitts i found at costco for less than $30.00 and have hardly had to use the hand warmers all season.
i am usually really hard on sled mitts and gloves, so i try and keep them economical and stuff that works for me.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
I have really cold hands and these worked since I posted this in 2009:
https://ty4stroke.com/threads/done-all-you-can-and-still-cold-hands-found-some-gloves.70452/
Sadly I don't think they are made anymore. There are some KLIM styles with the 2 in 1 Gore Tex. I always used the 'warm' chamber rather then the 'grip' chamber. The grip chamber transferred to much vibration to hands, the warm absorbs some of that and I like that better.
farmerschiferl
- Dec 28, 2010
- Hewitt,WI 54441
- 2017 Yamaha Sidewinder BTX-LE
- Hewitt, WI
give tobe Capto Gauntlet gloves a try i picked up a pair late last season and became my main riding gloves
https://us.tobeouterwear.com/800116-102-capto-gauntlet-hawaiian-ocean
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
I'm in search of the warmest gloves for riding. My fingertips freeze when riding in single digits temps, especially on my throttle hand. I have tried numerous brands and recently bought some Klim Powercross, which turned out to be disappointing (nice gloves, but my fingertips still freeze.) I want finger type gloves vs mittens. I already have the skinz type handlebar protectors on my sled (Sidewinder) as well. Interestingly, my brake hand palm will get too hot on my high setting, but throttle tips are still cold.
Any suggestions?
First off why did someone sell you these as cold weather gloves? I have a pair of these and use them only above 10-15 degrees f.
That being said, we ride anywhere from -30f to 40 above and usually carry 2-3 pairs of gloves as the temps change and wind changes. The best advice I can give anyone is get something that breaths to keep moisture away. Something waterproof for the same reason. And something windproof, as the wind is a huge factor. Gauntlets, and handguards make a big difference in all conditions. Also keep in mind the type of riding you do. As a trail rider may not move their hands as much as a ditch banger or mountain rider. If we find our hands getting cold, we kick up the ride a notch, corner harder, or hit some ditches to get the blood flowing to the hands.
The biggest mistake folks make is getting more form fitting/tighter gloves to gain touch and control. Not realizing how much circulation they are cutting off to their fingertips. The powercross is a great example of a glove that blocks wind, is dry and is designed to transfer heat from good hand warmers. In fact, it is a warmer glove while riding, than standing next to your sled. So keep that in mind. But it is not insulated at all, and will be cold below 10 degrees.
Most of us will buy gloves at least a size too big, to allow for liners and circulation. My gauntlet gloves are large enough for liners, and also allow me to pull a glove off and pull it back on easily and quickly. Air moves around, and I don't fear about circulation. The palms also transfer a great amount of heat from the grips.
So without endorsing any brand or model, those features are key no matter which glove. And don't be swayed by a "cool brand or design" only to find out they were made for tailgating and holding a cold beer in 45 degree weather. (there is a need for beer gloves too)
Good luck!
Anjill
- Mar 20, 2015
- NJ
- 2004 Warrior
2006 Attak
2013 Apex X-TX
All good points.
Keep your body warm and your hands will stay warmer. Your body is probably colder than you think.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I think the problem is circulation. I frostbit a few fingers years ago in the U.P. and they haven't been right since. Left brake finger and throttle thumb are almost ALWAYS cold.
