warning lite comes on as well as oil level indicator
crank shaft
Minnesota
I fired up the mighty Nytro 2day and about a min. into the warm up the yellow warning lite comes on as well as the oil level warning lite. I didnt hear anything out of the ordanaray but I shut er down and checked the oil. All was fine. I fired er up again and the lite and indicater never came back. Anybody else ever have this happen?
are you sure its not the warm up light???
It is the yellow warning lite to the far left bottem of the gauge pod and the low oil level indicater in the screen below the digital speed readout.
Did you recently change the oil? I had my light come on a couple of times after my first oil change last year. I just added a bit more oil and it never came on again. You might just be at that threshold of the low level limit of oil.
If it doesn't come on again, don't worry. Just remember to check fluid levels regularly.
Yes I changed the oil a few weeks back and ran it only once in the garage so I could recheck the level after it cooled. The level was perfect as it still is. Guess I will just have to keep a close eye on it. Thanks for the responces.
Did exactly that yesterday and the oil level is spot on perfect. Maybe a bad level indicater? Oh well.....Its under warranty ;)!
