uofm
I have a 2003 grizzly with 700 miles on it. How long is the warranty good for? The servo motor for the 4 wheel drive is apparrantly not working. You can jack the front end up and here it going into 4 wheel lock, and you can here it come out when you take it out. The problem is the 4 wheel light indicater does not shut off so the machine acts like it is in 4 wheel drive yet. The machine will not let you go over 20 mph then the rev limiter kicks in. Can anybody help. Thanks.
clutch
If your Grizzly is an 03 it is way out of warranty by now. If you bought the extended warranty there is hope.
BURMAD69
6 months is all the longer yammy will cover anything under warranty.
OGGY DOGGY
sounds like you need to talk to Grizzhopper.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Your connections just might need a good cleaning and then apply some dielectric grease on all your connections. But if you can hear it engage and disengage I don't think your servo is the problem? Check all you wiring, follow them back and look for a short or a wear mark, also check all your fuses and such. Sounds electrical to me.........Irv
