rx1warrior
Hey guys have a 05 warrior with filter kit and some clutching. Just purchased it lately took it out for a rip and noticed a low speed stumble not a bog but more of a hesitation. you can hear it in the exhaust note and it seems to be a around 2-4k rpms and I notice it when Im on the throttle hard at said rpm? This only lasts maybe 3-4 seconds and clears up and then she screams. anyone? sounds maybe like air fuel mixture?
yes i would like to know as well. mine is doing this now with ulmers kit in it. top rpms though are spot on for me. not broke in enough maybe? only have 1500km on it so far.
SledHedz
- Jul 21, 2007
- Northern Michigan
- www.sled-hedz.com
Where is the belt riding in the secondary clutch, when the sled is turned off? If it's down in the clutch a little? If so, this will cause the low end hesitation.
rx1warrior
my belt is just a little inside from flush, maybe like 32nd of an inch?
SledHedz
- Jul 21, 2007
- Northern Michigan
- www.sled-hedz.com
Adjust the secondary clutch by adding small washers to on the backside under the three screws.. I went to the hardware and bought various thickness washers. I would add the right size washers, to raise the belt about 1/16 above the clutch and see if that takes care of the problem..
