machz830
- Mar 2, 2010
Newbie here....just picked up a couple 2003 rx-1's and the one has a cracked airbox....at low end it has a hesitation and also only reaches about 9500 rpm's.....can the cracked airbox cause this.......also, I changed the oil and filter on them when I got them and (on the same sled) I seen a touch of fuel dripping from one of the carbs...it looked like it was coming from a probe(connected to wire) that goes into the bottom of the carb....it's held in by a brass nut...any idea's....Thanks, Dan
Turk
Tech Advisor
Keep riding it witrh a cracked airbox & your gonna blow up that engine.
machz830
- Mar 2, 2010
ok...Thanks Turk...will replace asap....do you have any clutching idea's for a stock rx-1?...Thank you, Dan
Turk
Tech Advisor
I have a plug & play set of heelclickers. Works great with the stock secondary. $150 shipped.
machz830
- Mar 2, 2010
Thanks Turk...as soon as I have the extra $$$,I'll get in touch with you..thanks again, Dan
Turk
Tech Advisor
Sorry 3 guys piped up right after i posted em so maybe next time.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
machz830 - welcome to the site.
Do what Turk says fix the airbox, some expoxy will do fine if the crack isn't too wide. Take the carbs apart and pinpoint where the leak comes from, fix the leak or your sled may burst up in flames.
Would you mind filling in your location in your user profile, it's a site requirement.
