island snow
- Mar 26, 2004
i know this has been likely been posted before,but if you could help me out it would great.I have been looking at a leftover warriorand i was wondering what the best setup for the rear suspension is . I have read that when setup properly it rides and handles great. I have ridden the 05 rx-1 and it rides awesome but i would prefer the long track.
monker
I had great luck with pulling the limiter straps up about half way, setting the FRA on the stiffest (#3 I believe) and having spring tension fairly stiff. I then fine tuned with the clicker. I'm not exactly sure where the clicker was, that is more rider preference. As I had it setup though, I could cruise trails at one setting, 2 clicks softer and studder bumps would disappear, and 2 clicks firmer and I could run whoops hard. Tansfer rods were usually between half and full transfer depending on what I was doing.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
I never adjusted mine, left it as my dealer had set it and it rode and handled great
Swiss Sledder
Island, take a look at the thread on the link below. This is in regards to LazyBastard's setup that many people tried on this board (me included) and had very good results. The post starts with someone doing the same changes to a Warrior. Should be helpful for you.
http://www.rx1.info/viewtopic.php?t=3403&start=10
