Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
Just got back from Quebec, St. Zenon, did 1350 miles and a little racing while there
On the lake at Le Cabanon, about 1/4 mile run we did several runs back and forth against F7, F6, F5 Firecats, 1000 Summit. It boiled down too Warrior vs. F7 nobody else except for a guy with a Big Bore 96 Ultra could hang with us (835cc). The Summit would get the Hole Shot and I would catch and pass him 8) The F7 and the Big Bore Ultra and the Warrior would run neck and neck and we would trade positions.
They could not believe how fast this Warrior ran
Then on the lake in front of Real Masse, about 1/2 mile run, I ran an Apex Gt several times back and forth and we where pretty evenly matched
Yamahammer485
Awsome stuff dude!
Is your warrior stock?
If not, what have you done to it?
7 skulls
Great post!
Just came in from riding my bro's warrior. Ran side by side with a good running F7 through 1/4 mile. Neck and neck outta the hole even though we have transfer dialed in to min. What transfer settings are you running? I found the warrior really hooks up better with a lighter rider and fumes in the tank.
Bob Miller
- Apr 19, 2003
- New Milford CT
I'm running 4 TPI valves with 160 main jets, Green Holtzman springs.
OSO primary spring, 14.5 mm rollers
Silver secondary spring @ 70 with shims
I also run about dead even with my buddy's 06 Mach Z
