tonka76
i was wondering if anybody uses hh 53g weights and ecp?how you set them up?i have a 04 warrior and weigh about 190lbs stock helix and a white white white spring no studs
Frostbite
I use heavy Hitters with my ECP kit.
I use an Orange/Silver/Orange primary spring and load the weights pretty heavily.
I use both the 3/4" and 1/4" allen bolts in the heel
I use a 7/16" steel in the middle with two washers
In the tip I use a 3/8 aluminum with an aluminum washer.
I have played with mine a bunch. Send me a PM with your altitude and I'll help you out.
By the way I use a silver secondary spring at 80 degrees.
Frosty
Frosty
