Warrior woes
dfroster
Kronenwetter, WI
2022 Arctic Cat Thundercat EPS
My dads warrior with 3300 miles did something strange yesterday. After starting it and letting it warm up like normal, I gave it enough throttle to move it forward slowly (4000 rpm about), it would begin to move and then it would abruptly stop moving. The engine made a thum, thum, thum sound when throttle applied and it wouldn't rev any higher than 3000 rpm or so. Didn't matter how much throttle I gave it or for how long I held it. It would just make the thum noise and occasionly back fire. Eventually, after jabbing the throttle alot I could move the sled and after about a minute of that the sled would run fine. Started it up today this morning (started easily) and it did the same darn thing!
I'm thinking maybe a TORS issue. Maybe water in fuel. Maybe dirty carbs. Any ideas or thoughts?
check the throttle cable adjustment. it like you said maybe the TORS.
Temperture change with very low fuel in the tank will cause condensation in your fuel tank.Same thing happen to my warrior last winter,could barely move,massive backfires along with flames a one point.Had to change the plugs in order to make it work properly.
