nauti1
I've looking to install a water temp gauge on my 08 nytro. What I need to know is what size is the hose "tee" do I need? The part you splice into the water hose that the sending unit screws into. I've seen 30mm, 32mm,and so on. The reason I'am asking is my machine is 3 hrs away and I want to get everthing I need before I go to the cabin again.
			Nine2Nine
nauti1 said:I've looking to install a water temp gauge on my 08 nytro. What I need to know is what size is the hose "tee" do I need? The part you splice into the water hose that the sending unit screws into. I've seen 30mm, 32mm,and so on. The reason I'am asking is my machine is 3 hrs away and I want to get everthing I need before I go to the cabin again.
I was looking into this last night as well, and found this, any other info from the pro's would be nice.
26mm or 1" Hose I believe is the size.
TurboTime
- Jan 3, 2006
- Cassopolis, MI
- 2009 Yanaha Nytro
Go to Ulmer Racing. He has a H2O temp kit for the Nytro with the tee...
BordnBill
x2 on the kit Ulmer sells.  I have one on my MTX.  Very simple install.
