rx1familyman
Does anyone have picture or part #s on a install of a temp guage. Tried the search engine with no luck. Would like to install before a big trip in a couple of weeks. Also a rear heat exchanger may be in the works if anyone has info on that.
BigDog05
Go to to FAQ section under tech section main page. Complete with pictures.
Also: http://www.rx1.info/viewtopic.php?t=153 ... &&start=15
rx1familyman
Installed temp guage, only thing i had to change is that i had to drop the guage lower on the dash because of the rs venture mirrors i installed. One more ? , what keyed wire did anybody hook into on a 03 rx1 shorty. The instructions say to hook into the blue w/ white stripe. I did not find this wire? Tested all the wires on the fuse block, and none were keyed hots, just constant hots. HELP PLEASE THANKS
Buckeye
- Lakes Region, NH
2 are through the key and 2 are off the battery. Red/white and red/yellow are keyed. Blue/white and blue/red are off the battery.
rx1familyman
