Cubby
- Dec 14, 2009
- South of Winnipeg, Manitoba CANADA
- 2015 Ski Doo 900 ACE Renegade Adrenaline
2007 Yamaha Phazer GT
yzman
Any where close to the motor , plus dont have it next to a rad , because a rad will cool down the coolent , and wont give you a good estamate of engine temp.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
http://www.ulmerracing.com/Digital Water Temp Kit.pdf
The Phazer is best put in the hose going to the bottom of the radiator. This will make your gauge accurate with the hot light in the OEM gauge.
Cubby
- Dec 14, 2009
Does the coolant flow from the engine to the rad then to the heat exchanger or the other way around?
- Apr 17, 2003
- Menno, SD
- Menno, SD
I don't remember which way the coolant flows for sure, but I believe it's to the exchanger first, then the radiator.
marpolsdofer
Srxspec said:I don't remember which way the coolant flows for sure, but I believe it's to the exchanger first, then the radiator.
You would be correrct!
marpolsdofer
If you look at the tank (facing the tank) it will flow towards the front of the sled from the tank. So it will be flowing to the right, in from the rear hole out from the front hole.
Cubby
- Dec 14, 2009
Thanks guys.
