junior_234
- Feb 28, 2013
- Stevens Point, WI
- 2014 Yamaha Nytro XTX 1.75 Push Turbo
What is the best water temp gauge/setup to use on the Nytro?
saskattakman
koso super slim digital works great for me guage was easy to install but the sending unit took a bit longer.
yzviper366
Just installed a koso on mine. Super nice and super sleek just hope it works well. I think koso is a pretty good name tho.
junior_234
- Feb 28, 2013
- Stevens Point, WI
Where did you guys get the kits from? Do you have to splice into any wires or are they plug and go?
yzviper366
Amazon everything you need comes with it but you need a adapter to put in your hose.
yamariv
What do you need for an adapter to make the Koso fit? Can you get it from Koso? Where's the best place to put the sensor?
I put the kit on from ulmer, it's a Daytona it works great, easy instal, small, and has a clock
yzviper366
The adapter is a aluminum piece that goes into the hose.and has a hole with threads for the probe to screw into.
yzviper366
http://www.amazon.com/gp/aw/d/B0041QMS0 ... -1&pi=SL75
http://www.amazon.com/gp/aw/d/B002LGUKQ ... L500_SS115
These are the two things I bought.
furg69
Where are u guys joining the t adapter to ? I just bought a koso also but haven't decided on a good location for the adapter.
Pm me your email or cell, I have my sled apart now and can email or text pice of everything. I would post them but I won't have time to do it for a while.
yzviper366
I was told to put it on the 4" of hosenkn the brake side of the thermostat so that's where I put mine.furg69 said:Where are u guys joining the t adapter to ? I just bought a koso also but haven't decided on a good location for the adapter.
yamariv
Anyone able to post some pics of their Koso install? I'm really thinking of picking one up, how are you guys mounting it on the dash?
Ill try to get some pics up later but what I did was take a piece of 2 1/5 by 5 inch of aluminum and bent it up using a vice and a hammer so it curved over the guage. I drilled a hole in the aluminum to mount it between the guage and the dash using the top hole and attached the temp guage with Velcro. It sits just above the factory guage.
yzviper366
