Water temperature gauge
machu
Ontario, Canada.
Those who have installed a temperature gauge what is the normal operating temperature , and what would be the max temp that you would shut it down?, also did thy use a digital or dial style gauge?, and was it in Fahrenheit or Celsius ?, and lastly what was the size of the sensor adaptor "T" ?, inside or outside diameter?
I put them in all 3 of my rx's and my rx mtn turbo don't quote me but I think back then 170 was normal it shuts off auto at 200 ish.
It was always Deg F. Cant remember but I think it is just a standard brass threaded plumbing "T" 1/2" with adapter for the censor to fit but may have been 3/4"
carsrtoys4me said:
Good snow my rx stays near 165°F....personally I don't like to let it get over 200°F. They will shut themselves off at 220 or near there. I forget the exact temp. I installed the digital gauge, this link is install for dial type
http://www.totallyamaha.com/snowmobiles ... gauge.html
Same for me on temperatures. I found a 22mm sender kit at Royal Distributing that worked with an analog gauge from Princess Auto- probably your cheapest option and it works fine for me. The gauge even looks stock.
Mine is in Celsius 60C to 80C is normal, Temp light comes on at 100C
Never had it shutdown so I can't give you that info
YammyRX1, I'm glad you stated the size, for some reason I was thinking 18mm, is that the Koso sending unit?, if so I believe it's cheaper at the Koso Canada website than at Royaldistributing, I have been thinking about ordering the gauge and sender from them.
It's a nice mod, I don't know why they would ever have a sled without a temperature gauge?, even my 08 GSX, I had to buy the module to turn on the display already installed in the gauge?, WTF?
Yes, it's Koso. The gauge really gives you piece of mind especially on those warm days.
