vsmpowered
- Feb 16, 2009
- Rochester , NY
- Nytro xtx Viper ltx se
What is the temperature of running stage 1 and trail kit compare to na vipers thanx
I have no issues on mine even at 252 hp or 13#'s of boost. I am running at about 170 all the time I just cannot let it idle long periods or it rises to 200. Even riding at temps above 32 F I was fine
Mine for some reason late last season developed a censor problem saying it was hot and put it into limp mode when the gauge was reading 170 then the temp warning light would flash and go from 100 to 200 and back and forth. I would shut it down and it would clear.
I think Allen Ulmer told me this has been a problem with the temp censor.
Studroes144
Stage 1 for me runs at 159-161, stock was always 167-169
vsmpowered
- Feb 16, 2009
- Rochester , NY
I thought vipers with turbo were on the hotter side
Studroes144
Possibly the trail turbo, the inner cooler on the stage 1 helps a lot in keeping temps down
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
My trail turbo always runs around 165-175 unless sitting and idling. Even then the fan would keep it between 195-200. Not sure why people say to not idle the sled with the turbo. I never had an issue with temperature. Just make sure you let it drop again before running it hard after sitting still.
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
We have 2 trail turbos and have the air cleaner outside sled and they run 165ish. No issues, even played in deep snow on a 40 degree day they run cool with lots of stop and go riding.
Studroes144
What are the intake air temps with the non innercooled trail turbo? My stage 1 holds a steady 59 degree intake temp and when idling for a minute or more it gets up to around 65. Intake heat for a turbo sled can potentially be more harmful than engine heat.
vsmpowered
- Feb 16, 2009
- Rochester , NY
How can i find out intake temp?
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
On your gauge. one of the bottom selectable displays.How can i find out intake temp?
vsmpowered
- Feb 16, 2009
- Rochester , NY
Interesting
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
I could be wrong but I think it's a B.S. reading on the MPI kit because it is reading the intake to the turbo not the engine. Pretty sure it is the sensor in the cross tube between the filter and the turbo.
yamahaguy
Ride SAFE
- Apr 20, 2014
Correct. The sensor is in the cross tube. So if you're running your air cleaner outside of the sled that sensor reads outside temperature pretty much. Would be nice if they put that sensor after the turbo, that would be a more useful temperature reading but I'm guessing MPI had reasons for putting it where they did?? Idk. I have never liked the idea of putting the intake under the hood because you're always starting with a warmer air to begin with.
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
I wasn't sure if the ECM pulled the temperature from the MAP sensor or something. I would think it would need to know the actual temperature going into the engine for proper fueling but who knows. Maybe Matt or Alan will chime in on that one.Correct. The sensor is in the cross tube. So if you're running your air cleaner outside of the sled that sensor reads outside temperature pretty much. Would be nice if they put that sensor after the turbo, that would be a more useful temperature reading but I'm guessing MPI had reasons for putting it where they did?? Idk. I have never liked the idea of putting the intake under the hood because you're always starting with a warmer air to begin with.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
I was wondering about intake air temp also.
In my opinion if your not getting the air temp after the turbo ( charge air temp) your really not getting any good info.
I work on diesels for a living and charge air temp is critical. To hot and its grab time.
- 12K
