Phazer2Viper
- Apr 14, 2014
- Slinger, WI/ Three Lakes, WI
- 2015 Viper LTX-DX 15,000 miles and counting!
2008 Phazer GT 128" track 10,444 miles (sold)
2008 Nytro RTX 136" 3800 miles (sold)
2000 Phazer 6500 Miles (Sold)
1990 Phazer II 10,000 miles (sold)
So my friend has a zr7000 with about 900 miles on it. It will shift into reverse but wont shift into forward until you turn off the machine and turn it back on. When you do that it is in forward. I swapped his actuator with mine and still does it. We tried swapping his forward and reverse relays with no luck. any ideas? thanks
FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
- YOUTUBE
- FrozenTows1
Belt deflection too tight?
PAvector
If you have a 14 or 15 with the wobble bearing on the upper shaft, if it’s worn bad the top gear will drop enough that it won’t allow engagement with the reverse gear. Also as previously stated, if the belt is too tight, the reverse won’t engage properly. Some people had the plastic fork guides break, no sure if that would cause his issue.
Phazer2Viper
- Apr 14, 2014
It was the reverse button! Switched it out and it works fine.
Mills
- Dec 4, 2007
- Elk Mound, Wisconsin
- '21 SRX, '14 Viper RTX, '06 Apex, '99 SX 600, '74 TL433F,
have they gotten a Trail 13 reroute figured out up there in Three Lakes or is it still shut down?It was the reverse button! Switched it out and it works fine.
Phazer2Viper
- Apr 14, 2014
sounds like they have a reroute figured out but it wont be open for at least a year or 2. they will have to build a new bridge.have they gotten a Trail 13 reroute figured out up there in Three Lakes or is it still shut down?
