T-Nytro
Good to hear.
Skydog
Right on buddy just had a bad day/night Wed.
hahahah
Skydog
hahahah
Skydog
nytro boy
Skydog said:Right on buddy just had a bad day/night Wed.
hahahah
Skydog
Hey Skydog,
You got a boost gauge on your sled, if so what PSI are you running and did you end up going to the 27/29 pullies?? I am trying to dial mine in right now but same as you having nothing but issues!!!!! and with the 27/29 pullies I am showing 11PSI ???? should be 5-7 ?? I DON"T GET IT!
Skydog
Running 9+psi! With some race fuel. 25 upper 29 lower At what RPM???
Thank you Skydog
Thank you Skydog
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
- www.jannettyracing.com
Skydog
Thank you Ted i have read that about 500 times haha
Skydog
Skydog
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Great to hear you're getting closer on fuel mapping.
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
Skydog said:Thank you Ted i have read that about 500 times haha
Skydog
I didn't know, Thought it might help.
Skydog
TurboJamie said:The nytro box can be tuned, I had mine tuned which was fine for sea level, its a little screwing around especially with the CO's and that Red/Blue setting the altitude comp is the only one causing you the hiccups, it needs to be dead on to work.
no no no Ted dont take that the wrong way.
THANK YOU !!!!!!!!
Skydog P.S. Boy rode last night it is all most up to my level of right on!!!! YES!!!!!!!!!!!!!!!!!! If 100% is right on she is about 96% right now!
The big key that saved me was this by Turbojamie!!!((((Red/Blue setting the altitude comp is the only one causing you the hiccups, it needs to be dead on to work))))) HAHAH THANK YOU
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
Skydog said:TurboJamie said:The nytro box can be tuned, I had mine tuned which was fine for sea level, its a little screwing around especially with the CO's and that Red/Blue setting the altitude comp is the only one causing you the hiccups, it needs to be dead on to work.
THANK YOU !!!!!!!!
The big key that saved me was this by Turbojamie!!!((((Red/Blue setting the altitude comp is the only one causing you the hiccups, it needs to be dead on to work))))) HAHAH THANK YOU![]()
Good News!
Skydog
Yea thank you guys! LOVE THIS SITE AND PEOPLE!!
Skydog
Skydog
TurboJamie
How's she runnin now matt?
Skydog
Man buddy VERY VERY GOOD!!!!! I need one more day to make sure it is right on the money! The big thing (like you said) was the red and blue! The one little thing is when curising at about 40-50 mph it will creep lean.(not moving the gas) Can not go any richer on the green or up on the green blue it then will be pig rich at 10-25 mph just curising. Any input on that one?
THANK YOU SO SO MUCH!!!! Matt P.S. Now to get the clutching on it hits the revlimiter bad out of the gate like 3-4 times.
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
Skydog said:Man buddy VERY VERY GOOD!!!!! I need one more day to make sure it is right on the money! The big thing (like you said) was the red and blue! The one little thing is when curising at about 40-50 mph it will creep lean.(not moving the gas) Can not go any richer on the green or up on the green blue it then will be pig rich at 10-25 mph just curising. Any input on that one?
Give me a call I will set you up with Clutching.
TurboJamie
Matt try moving your yellow up and see if that helps you move it 1 full point and lets see what happens.
What are you running in your clutches?
