Wet left foot
crank shaft said:
Well the problem has been solved. Sorry but I dont have pics but what you need 2 do is remove the seat and look at the very front of the tunnel just to the rear of the exhaust flange cover you will notice 2 large holes. 1 On the left side and 1 on the right. Calk them sumbiotches up and run the bead back several inches along the exhaust shield under the seat. It is real obvious once the seat is removed. No more leaks. The little alum fix from yammie dont work so remove it so it dont fuk up ur clutches when your belt blows.
This is very useful information. Thx!
phatkid said:
klim boots ....... problem solved no calk , duct tape or grocery bags needed and stylish too.
i like that bags because if you hit a critter while sledding you can take it home without the mess! :drink:
i have a few pictures of my seat off but I'm not sure what or where i should be caulking. Please help, I hate having wet/cold feet!
i pointed out areas that i think should be caulked hopefully I'm some what close.
