Berg570
- Nov 18, 2012
- Cle Elum, Wa
- Sidewinder MTX
I know most of you are familiar, but myself being new to Yamaha 4 stroke sleds just learned of the Nypex.
Holy %*#&!!!!!
Is this not the perfect sled? Nytro chassis with the mighty Apex motor.
Please enlighten me. What, if any, faults are there?
Is there a "shop" that does this if supplied the two machines?
How much does the actual fabrication cost?
This sounds like the ultimate sled to me.
Holy %*#&!!!!!
Yamahammer485
Berg570 said:I know most of you are familiar, but myself being new to Yamaha 4 stroke sleds just learned of the Nypex.
Holy %*#&!!!!!
Faults are the initial cost, your blending two sleds into one, the apex likely has to be a wreck and the sled is a one off. Completed ones are selling between $25000 and 30000.
Check out this link
http://www.diamond-smfg.com/Nypex.html
Berg570
- Nov 18, 2012
- Cle Elum, Wa
- Sidewinder MTX
$30K is a fault!
I have an Apex, and have access to an '09 Nytro with a blown motor for $3500.
I wasn't sure of the extent of fabricating thats involved. But appears to be a massive project?
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
I too was interested and yes its a MASSIVE undertaking. Even skilled builders caution this build as its very labor intensive and ironically its not getting the motor mounted or drivetrain hooked up, its the zillion brackets and fab work to get everything else mounted.
It can be done it has been done. Its a great combo but not the end all be all.
In the end I made the decision the work wasnt worth the end result.
Berg570
- Nov 18, 2012
- Cle Elum, Wa
- Sidewinder MTX
Way to rain on my Nypex parade guys! Haha.
I believe you are right, that its not worth the big hassle and cost.
big_red1a
Check out the Revelstoke boys run a business putting an Apex engine in a custom cromoly frame with the Polaris ergos.
SRXSRULE2
I'd say buy a new viper, lots of room for a turbo. Any Cat skid can be bolted in (such if you're planning on making a mountain sled) and then go from there. Only weak link I see is the chaincase.
09nytro
Well you can fix the chain case by changing out the gears and chain....I think team has gears and chains ....that's what I'm going to do
new4stroker
Is there anyway to change the chaincase on the viper to a true yamaha chaincase easily?
yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
Easily? Nopenew4stroker said:Is there anyway to change the chaincase on the viper to a true yamaha chaincase easily?
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
The gears and chains are yamaha, it's been posted online numourous time
4strokes are better than2
SRXSRULE2 said:I'd say buy a new viper, lots of room for a turbo. Any Cat skid can be bolted in (such if you're planning on making a mountain sled) and then go from there. Only weak link I see is the chaincase.
would not be in the same league the nypex is a great combo that yammi should have built but has not,with the right motor work & turbo kit they are plain nasty.
you can build them with a stock nytro mtx chassi have to grind off chaincase you use the apex one,from there its allot of little time consuming stuff.
you are not to far from cr racing they have done 3-4 of them you could call them for a price but it wont be cheap,they may be able to supply parts though if you want to do yourself.
there is a bunch of info on them in the snowest turbo yammi section.
Berg570
- Nov 18, 2012
- Cle Elum, Wa
- Sidewinder MTX
Thanks, I will check it out.
Im going to buy the blown Nytro I think. Even If i only rebuild the motor. But will have the option of building a Nypex should it work out.
DeanO
I have a Nypex with a 174 3" for sale if you guys are interested. Quite the build. insane to ride.
Vmax4
- Apr 18, 2003
- Orondo, WA
- 2010 FXNytro MTX 162 SE with a 270 hp MCX Turbo and assorted goodies!
Contact Laird McDougal in Revelstoke, BC. www.powerhousecustoms.ca that is a COOL machine as well. his is for sale.
