what bender kit do i have?
krauss2005
northwest ohio
i just bought a bender turbo kit and it didnt say what say what stage it is how do i know what it is and how much hp im gonna have? i gave 1000 dollers for it is this reasonable?
for any turbo setup 1000 is a good deal...
I would look at the turbo and see if there are any markings on the thing, the size of the turbo helps show which one it is, and also, does it have an intercooler or not?? just trying to get you started and closer to your anwser.
Probably a stage I. If it is a stage II, there should be a switch somewhere to change between boost levels. Mine is by the pitot jet on the chaincase side.
The first year or so of the Bender stage 1's didn't have an intercooler integrated into the airbox. All the stage-2's did, then some of the later year stage 1's used the same airbox as the stage 2's with the intercooler...
Likely has a GT2554 and a single stub muffler off the outlet.
Does it have an oil pump and tank at the rear under the turbo? If so, that is a very early version as they switched to engine oil supply later on. Or it was upgraded at somepoint.
If you ever need any replacement parts or upgrades, Justin Fuller at Full Power Performance had bought up all the Bender Turbo Systems inventory and all the component fabricating fixtures, jigs, etc when that company folded and sold off. He can support all those models...
