woodynh
I just got a 06 Apex GT and was at a dealer yesterday and they had the same sled but the rear monshock had a silver spring.
My has a yellow spring. Is the stock spring yellow?
LJ 452
The Ohlins shock uses the Ohlins spring which is yellow. The other Mono shock sleds (non-EC/Ohlins) will have a silver spring.
danq
Agree, Stock GT Monoshock Ohlins spring is yellow. Aftermarket "big boy" springs could be any color. Mine is blue for example
MUSKIE
- Dec 21, 2006
- SW Ont.
- Custom - 06 Apex
Yes...stock is yellow.....
woodynh
Thanks guys. I planned on getting the shock revalved by pioneer and a different spring but just wanted to know what I had before I talk to Pioneer.
Thanks for helping out a newbie to yamaha. I am sure I will have many more questions.
LJ 452
There should be a part number printed on the spring itself, it may have worn off but it was there at some point. You can write down the number then do a search on here with that number and it should tell you which one you have. There are three or four Ohlins springs that are available, and there all yellow in color. Aftermarket ones may be different but the Ohlins ones are yellow. As for using the Yamaha site for the part numbers, that likely to be a dead end as they have there own part numbers for the springs. The number written on the spring will be a Ohlins part number. Little confusing but I'm sure it will make sense once you do a search.
snowbiscuit
ohlin spring
Sorry to bust in but I have an Ohlin spring with number 00696-14/60 L077. What is the spring rate? Tnks Jim
Port-Parts
TY Advertiser
- Sep 18, 2003
- Port Washington Wi
- www.portyamaha.com
- 2012 Nytro RTX
2018 Sidewinder BTX SE
Re: ohlin spring
Spring rate on that spring is 6.1
snowbiscuit said:Sorry to bust in but I have an Ohlin spring with number 00696-14/60 L077. What is the spring rate? Tnks Jim
snowbiscuit
rate
Thanks port, I was told it came off shorty GT but must have been LTX. Does have a good, pretty stiff ride on 06 RTX
