What do you use to keep the White, White?
Sorry Boyz I dont mean to jump in! But Bleedyamaha posted above to run the 8DN Belt! Is the 8DN belt stock for the 14 Viper RTX or is the 8JP? which one is better? Drive? Less Belt dust?
. Yamaha tim had a 8dn put on his 14 sled and it didnt slip as much therefore less brake dust and pulled better. 8jp is stock on them all I assume so alot of ty guys switched to the apex nytro belt and added another washer to the 3 bolts on the back side of secondary to help with belt deflection as the 8dn is a little bit longer.
Whatever is on the back of the sink. I have been using it mixed with a little elbow grease for years.
There are a lot of cleaners out there that may well do the job. The key is to find one that is not harsh and does not remove wax/finish. As an example, dish soap makes an awesome window wash for bugs, but removes wax finish from vehicles as well.
Get a good polish and finish before it gets dirty and the stuff should wash off with an ordinary car wash soap. I use S100 total cycle cleaner on my Harley as a pre wash. I foam it down then pressure wash it off. This takes off the big and grimy stuff so I can come back with a mitt and a mixture of Meguiar's car was soap and water and do the entire bike. before power rinsing again.
