culvert
I have a question on what type of epoxy/glue to use to hold the brass tubes for the vaccuum lines to the carb boots.
I was doing a carb sync and when diconnecting the lines the brass tube came out of the carb boot.
What will work and not be effected by fuel/oil?
boat.man
I would replace the boot. if the repair job fails and the brass tube gets ingested into the engine it could cause some real damage. its just not worth it.
Black 1000
I second that.
Travis Moore
If the material is hard enough, use a NPT threaded barb.
T
T
SnoWarrior
- Jan 13, 2005
- Long Island, NY
- 2024 Sidewinder L-TX LE
Happened on my Son's warrior, we put it back in and put a little rtv around it, been 2 years and still fine.
Also Yamaha sells the same adhesive that is on the barbs.
www.yamaha-motor.com/sport/apparel/apsu ... etail.aspx
culvert
Thanks, SnowWarrior
I was going to try some type of RTV just looking to see if there was a proper one to use.
irondog rtx
glue
I use jb weld or rtv black or hytemp for this stuff good luck can be treaded allso all will work out
