Apex18
I just got back from riding, and i thought i would have a look under the skis. I have about 350 miles on my 07 Apex, and the carbides are probably already half wore. It's pretty sad how yamaha only puts on like 2 or 2.5 inches of carbide. With such a heavy front end, and crossing roads often, they are not going to last. So what are people replacing them with? Id like to have at least a 6 inch carbide, i don't run studs but i want something that is not going to wear fast from crossing roads, so i'm guessing the longer the carbide the better. Any ideas? These are to be used on the stock yamaha skis. Thanks guys
ROCKRTX
Bergstrom triple point have a good product.
MCApex44
- Mar 30, 2006
- Western New York, Chautauqua County
- 2014 Viper RTX SE (sold)
The longer the better is not the case with making carbides last longer...its the quality of the carbide. The old saying you pay for what you get holds true here. Plus without your sled being studded...a longer carbide will might actually have too much "grab" and your rear/track will be/feel loose(as in like nascar loose or like you are hitting an ice patch). You will probably be fine with 4" carbides with an unstudded sled...just make sure the carbide is one of quality.
Daranello
Suspended
ROCKRTX said:Bergstrom triple point have a good product.
I hope so I just bought some 8" triples for the Attak with 108 studs
schroon
- Mar 8, 2006
- Schroon lake, NY
- www.pacific-custom.com
I have 144 studs and didn't like the way the 6" dooleys steered, so I'm trying 8" dooleys.
yamadog1
carbides
i have used scotts products and i have always been happy.
MCApex44
- Mar 30, 2006
schroon said:I have 144 studs and didn't like the way the 6" dooleys steered, so I'm trying 8" dooleys.
I ran the 8" doolys and 144 studs all of last year and was happy with the results. Took care of the darting but pushed a bit sometimes in the corners. The reason I chose to switch to the Pilot skis was due to the hard steering I had with the 8" doolys and stock skis.
MadMax
Unstudded I use 4 1/2" studboy duece bars......... They take a beating.. Run straight and corner as good as shaper bars.
MM.
YAM182
- Dec 19, 2003
Unstudded 06 Apex GT.
Tried 6" shaper bars last year and seemed very good even though they wore from riding in poor early season conditions
Going to put on the 6" Duece bars for this winter.
Ported Hornet
I run sharper bars.
favarcat
MadMax said:Unstudded I use 4 1/2" studboy duece bars......... They take a beating.. Run straight and corner as good as shaper bars.MM.
I use the same. Always straight as an arrow. Cut thru any tracks in the snow.
JohnWI
I had good luck emailing (never on the phone) with Scott Bergstrom this summer. I tried lately and maybe he's got a spam filter that is nixxing me.
I just cut him a check and mailed it to him. I think it took about 2 weeks. I probably couldn't reach him for about a month prior to just trying good ol' USPS.
I haven't tried them but he recommended I start with 6" TPs for my setups and general style. (pretty green riders and the Rage has 108 picks up the middle and the Vector has 144 across the whole track).
yamaouch08
- Jan 17, 2006
- Otisville,Michigan
- www.chapmanssports.com
The shaper bars work awesome,I use them too!favarcat said:MadMax said:Unstudded I use 4 1/2" studboy duece bars......... They take a beating.. Run straight and corner as good as shaper bars.MM.
attak-d
- Sep 20, 2006
- North Freedom,WI and Iron Belt,WI
7.5 shaper's on c&a razor's
Apex18
Thanks for all the info guys... I'm going to look around at the different brands. I think i'm going to go with something along the lines of 6 inch.
- 7K
