henseljg2
Did my first ride today with my new coolant temp meter in. Meter reads temp between bottle and radiator. It consistently ran 160-165 F. Anyone else run similar temps? I belive this point is the outlet of the motor once the thermostat is open. Sled is a 2011 apex xtx.
160 is where mine is 90% of the time. Temp goes up in low snow conditions of course
henseljg2
Ok. Thanks. Sounds like 160 is the baseline.
^X2, 160*-165*F normal riding, slightly higher when running through"snirt"
UP Michigan rider
- Feb 9, 2013
- Central U.P.
- 2012 Apex XTX
They run hot! Its a sport bike, high RPM, high compression ratio, EPA bullshit lean running, machine originally made for a motorcycle. When I had first got mine, it shut down on me a few times when I was idling too long. There were a lot of articles on this and basically they put way way too much actual antifreeze , like north pole conditions worth. So basically there wasn't enough water in there. My dealer helped me out and I think I put a product called wetter water or something like that, I can't remember but I haven't had a problem since.
Product does work.Water wetter works best with more water than coolant . Have been pumping it thru for a few years in the quads and built banshee. As for the sleds , DO NOT add more water then coolant .!
Jonesynl
- Nov 6, 2014
- Roberts Arm, Newfoundland, Canada
- 2008 Apex MTX SE
I've my apex, I run 50/50 premix Coolant with Water Wetter also added, I also have added a extra big real cooler from a fire cat, so I did add about another half bottle of coolant or more. I run between 75-78 degrees in powder, on hard pack I run 79-82 degrees. I also seen scratchers drop her temp 1-2 degrees.
Jonesynl
- Nov 6, 2014
- 2008 Apex MTX SE
When I drained the coolant out of my apex last year it was 100% coolant. Not mixed with water
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
167 degrees Farenheit
ShootToThrill
167-170 on my 12 xtx, warm up light goes off at 69 degrees. Easy to tell when the rear exchanger gets blocked off by snow/ice, it climbs quick to over 200.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Yup, that's what mine runs at.
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
I have my temp sensor where the coolant comes out of the top of the engine before the thermostat and runs 170/180 F, depending on snow conditions. I think with the sensor there you get actual engine temp.
02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
- ramody44@yahoo.com
With some 50/50 yamacool added along with water wetter I run between 160F-167F. Usually 163F is my norm.
Winderallday!
- Dec 4, 2007
- SW, Ontario
- 2018 Sidewinder DX
Same here, sensor location and temp readings as TBay on my 11 Apex 128
TBay Sledhead
- Jan 16, 2005
- 06 Attak
01 SXR Long Track
Yes but where is your sending unit located?With some 50/50 yamacool added along with water wetter I run between 160F-167F. Usually 163F is my norm.
- 6K
