jr_2117
- May 9, 2009
hey guys. i got the stock ripsaw on my xtx, and i find that when im in deep powder that im hitting my rev limiter all the time. i do alot of trail riding and alot of off trail deep powder. whats the best track anyone has run for these applications. and id rather not modify my tunnel but if i have to then it was meant to be.
LeeKo
I am pretty happy with my 1.325 cobra on mine. I think it a much better on trail/off trail track and no mods are needed. If you ride more off trail you can go to a 1.5 crossover track, you may have to remove the front heat exchanger protectors. I am not sure if you have to but it is not a big deal to do.
meatman
- Apr 14, 2009
- Fort Saskatchewan , ab, can
- 2017 Yamaha Sidewinder XTX
thinking if changing to a 2inch, have the mountain phazer and like the profile. does anyone know if i can just change the track and drivers, or is there anything else i need to do to fit this in. thanks.
sorry for tapping your thread.
Mtnviper
- Aug 19, 2003
- Burlington Wa.
- fourstrokesolutionsllc.com
If the track you want to use is a 2.52" pitch, which most if not all 144" tracks are. Then you use the stock 9 tooth drivers with a 2" track. Just have to remove the tunnel protectors.
Apex & xtx
I personally think that a 144inch rubber band would be better than the stock track but i was looking into a 1.75 cross country my buddy has one on his 08 Renagade and he can go through anything and 144 and up track can go thru with that track in only 136 track.
