TLM
- Jul 19, 2014
- Hortonville, WI
- 2012 Nytro xtx, oft relocate, oilite bushings, comfort clutch, tunnel block, tailight relocate, cr10EK plugs, copper donuts, tuner skis, Grizz Tracks gusset kit. Excell x wheels. Mo-Flow console vent and curved vents.
Hi all! I have been looking at some headlight options and I came across some xenon gas bulbs were interesting. Also I have been looking into LED lights to see if they are an option. My question though, is the wattage of the stock headlights. I am curious of the wattage and draw on High/low beam. I didn't check the manual yet, but I figured somebody has to know on here! Thanks in advance. Oh, the sled is a 2012 xtx.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Going by memory, 55 watts on low and 60 watts on high per bulb
m.schuey7
- Feb 4, 2014
- Colorado Springs, CO.
- 2011 Yamaha Nytro XTX
Yes,
55watt low and 60high.
I replaced my stock bulbs with 65w / 100w Rally Car halogen bulbs and adjusted my headlight up a bit from stock, not in the trees but close
I ride 95% at night and quite fast at times and this setup works great, also very low cost, got my bulbs at NAPA.
RDCrazy
- Nov 27, 2014
- Northern Illinois
- Nytro xtx
Won't a 100 watt bulb melt the wire assembly?
TLM
- Jul 19, 2014
- Hortonville, WI
The LED kits run much less wattage, wouldnt this be beneficial to other electrical items on the sled like the hand warmers? The kits I looked at today replaced a 55/60 watt bulb...
RDCrazy
- Nov 27, 2014
- Northern Illinois
- Nytro xtx
I read LED lights are no good.... They are not as bright as conventional light bulbs.
kokonut
- Sep 15, 2012
- Moncton,NB
- 2011 XTX Nytro
I bought the Piaa's Light is fantastic,
m.schuey7
- Feb 4, 2014
I do make a habit to turn the high beam to the low setting every time I come to a stop as not to melt the plastic headlight lens, no problem with wiring.
