crazy680
What kind of fuel pressure regulator do the rx-1 turbos run?
I tried a mallory #4309 3 port boost referenced fuel regulator but for some reason I couldn't set the fuel pressure on it. I could not set it to less than 25 psi when the walbro electric pump was running at a idle. Is there something wrong with the regulator or does it need a different fuel pump that doesn't put out as much pressure as the walbro electric pump I have now. It has a good sized fuel return line as well..
peteracing
That's exactly the # 4309 i use on my kits and it can be adjusted to
the pressure you want . i use 10 psi plus boost press. are you using the
bottom barb to return fuel to tank? witch walbro pump are you using?.
peteracing
btw.. no kinks or squeze on your return hose? what size is your return
hose?..
hose?..
crazy680
peteracing said:That's exactly the # 4309 i use on my kits and it can be adjusted to
The number on the pump is- GSL 393.. yes I'm using the bottom bypass port for the return line.
I think I'll check to see if something is restricting my fuel return line..
peteracing
try adjusting while pump runs go slowly adjuster is sensitive.
crazy680
OK I found the problem.. The regulator was fine, but the return line was too small for my pump and regulator combination that would restict the gas flow. I was able to adjust the fuel pressure when I tried a larger line.
I have it set to 6 pounds base pressure.
BTW how much base fuel pressure do the mc express and other kits run?
peteracing
I run 10 psi , 6 is acceptable.
