Vmax540
- Jul 25, 2005
- Clarion Pa.
- www.vintagevmax.com
What lenght & Height tunnel protectors with stock track
What lenght & Height tunnel protectors with stock track and just over an inch studs ? I was thinking maybe finding some ~1" aluminum tubing to put on the outside since I will not stud the outer bans.
09phazermichagan
just did the same with mine i used 96 1.150 studs and got the yamaha tunnel protectors all they are is 1 inch aluminum square tubeing. yamaha protectors go from the heat extanger all the way to the back bumper mount they have a curve at the rear of the sled so they stay flush with the tunnel yamaha says mount 75mm from side of tunnel so around 3in should put them right over the windows
Vmax540
- Jul 25, 2005
- Clarion Pa.
09phazer Thank you !
spike337
I think back in the day i just held up a 3" ratchet extention and measured it that way. Just a little tip, for what it's worth.
