what mod to do that won't affect fuel economy
yves F 7
Quebec,Canada
What mod do you guys recommend that will not affect my fuel economy,me sled is a bone stock 07 apex gt,the only thing i have is that mi track is studded,thanks for your input
Try dropping a gear on top. You'll have more low end pull and won't sacrifice any up top. Fuel economy, if affected, would only be a slight drop off and your clutching should still be pretty close.
bottle of "COOLWIPP" :nos
Try a radicle paint job with new graphics. Fuel mileage will stay the same. It might not go any faster but it will look faster :bling It all about perception!!
Try a WHITE spring wound 3/3 in your secondary from a APEX LTX 136" its like $20.00 and you'll gain a couple of sled lenght out of the hole, my buddies '05 RX1 121" did this mod and ROCKS!!!cheap and efficient... ;)! I have a spare 1 in my tool box if you can't find any to try out.
airwolf,i was thinking about that but does it affect the economy,and how much will it affect it,at 1.08$ a liter on the trails,you have to think about it,for you us guys it's 5$ a us gallon
totallynytro real intelligent reply.
Shivesy,i will do that this summer
apltx08,interesting,but i do not drag race,i only want better performance.
thanks for your time all of you.
Put in Woody's 1.450 studs, if you do not run that already. Change to a 22/38 gearing and get an Ulmer clutch kit. You may burn 3-4 litres more at the pumps to a full tank.. Not a big issue..
If you really want to harness the power and make your sled gain about 3-4 sled lengths faster out of the hole and acclerate alot better, then you need to run those studs...
