Going to be adding a fourth wheel kit to my attak.I have oversized wheels on it know I didnt know if I should add a marginal wheel kit as well, and if I do should I put it towerds the back of the suspension on in the front or should i put both kits on. I do seem to be burning the slidders in the back of the sled. A buddy has the same sled and dosent burn slidders at all. He has over sized wheel kit and forth wheel kit as well as a wheel kit on the front of the rails. Thanks for any feed back.
im burning through my slides too. where did you get the oversized wheels and did you have to modify anything or was it a direct swap for the oem wheels?
I put polaris wheels on. They have been on for two years and I have had good luck with them. The only thing you have to do is trim down the bracket for the inner wheels in the rear so they run where they need to in the track. The oversized wheels work well but i still wear slidders towerds the back.
