When installing Oilite bushings, do you retain the plastic
andrew1984
Woodbridge, Ontario
When installing Oilite bushings, do you retain the plastic cupped washers on the inner control arm bushings??
It's damn tight fit and I'm worried about doing damage by forcing it into place, however if the plastic washers aren't installed then there is significant slack.
What should I do?
