DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Aside from the obvious torn lugs or pulled thru studs, how do you know when you should change your track? I have 12000 Kms on mine and it looks as good as the day I put it on.
Thanks.
DMC
Thanks.
DMC
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Wow lucky guy!Aside from the obvious torn lugs or pulled thru studs, how do you know when you should change your track? I have 12000 Kms on mine and it looks as good as the day I put it on.
Thanks.
DMC
I would say if track stretches past the point of adjustment?
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Are you tuned? Honestly. 10k miles is my personal opinion.Aside from the obvious torn lugs or pulled thru studs, how do you know when you should change your track? I have 12000 Kms on mine and it looks as good as the day I put it on.
Thanks.
DMC
Turboflash
- Mar 18, 2019
- Southern MN
X2
DMCTurbo
- Nov 12, 2005
Yes tuned for 10000 kms. I plan on replacing it after the season but just wanted others opinions.Are you tuned? Honestly. 10k miles is my personal opinion.
mario750
I think he said that he has 10000 km on his sled so it’s around 6k miles.Are you tuned? Honestly. 10k miles is my personal opinion.
We rode all day today and my bud has a 17 with the ice cobra since new with just over 8000kms. About 10 miles from home, he started hearing a slapping sound. Outside belt separating the length of three bars. Cut it off and took it easy the last 10.
I be surprised to see 10000 miles. I say if you make it to 10000 kms, it's time to change it.Are you tuned? Honestly. 10k miles is my personal opinion.
Red Rocket
- Jan 5, 2015
- Ontario, Canada
- 2023 Yamaha Sidewinder LTX DX
Mine lasted about 7000km before it tore a 4 double backered studded section out of it. It was tuned 275-290hp pretty much since new and i drive it hard .
If you get 10oooKm i think thats great with this much power.
I upgraded to a 1.5" storm track and love it so far. It hooks up much better!
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
You will be fine. I like to really keep a close eye on it after about 7-8 k. Miles. I also burn my track after every 1000 miles or so. The fuzzy stuff in the windows and on the outside edge of track.Yes tuned for 10000 kms. I plan on replacing it after the season but just wanted others opinions.
DMCTurbo
- Nov 12, 2005
I'm looking for an SRX new take off track if anyone has one in my neck of the woods.
Dr. FeeLGooD
If you have that many miles and it looks like new you are not hard on it and it will be fine. Keep an eye on it.
