where are you mounting O2 sensor?
saskatoon, saskatchewan, canada
Website
www.arrowheadcustoms.com
i mounted mine in down pipe after turbo housing but i think i mounted it too close to the turbo. mine is only about maybe 3 inches away from the outlet on the back of the turbo. the reason i mounted it there is that there was the best room for it to clear everything there. i do think that if it is running for a long time at partial throttle it super heats the sensor and starts to get false lean readings.
what do you guys think?
what is the theoretical best distance from the turbo for it to be mounted? and with mine being there would it read a little bit leaner or a little bit richer?
I mounted mine in the tail pipe and I think it may be too close to the natural air. My readings seem to be a little jumpy. I may try the innovate gauge and see if that reads the same as the NGK.
mine in the same place as yours dallas seems like the readings are good on my ntk so far a little rich at idle but thats it you can watch it work as you add choke .
Get the innovate but buy it from dynotune, much better price. My indications now are that my narrow band may have been giving me false impressions.... still need to do more tuning.
O2 sensor
have MCX rear
Where is the best place to mount the wide band sensor.
Before or after turbo????
Thinking after but will it make a difference in readings?
and where is the safe zone for mixture 12 - 12.5?
For my Stage 1 SC, I put the sensor in the front of the exhaust canister. I cut a hole in the heat shield over it and ran the wires right along side the tail light wires. I have been told this is too close to the outlet of the exhaust but I figured it would give me a more accurate reading on the throttle than if it was in just one pipe on my Whiteknuckle exhaust.
Jim
