stephenpen
I've been reading that the chassis is not a good ground. I already grounded everything to the chassis.
If its not a good ground can I just run a wire from the battery ground to my chassis ground. Or will that screw things up.
Where is everyone else picking up there ground ?
ralger
I have been using ond of the bolts that holds the reverse beeper. No issues in 3 years. Also, have used the chasis - agaon no issues.
Nikolai
I have my ground bolted to the steering hoop and haven't had any problems.
HYFLYR
What Nikolai said. All new nytros are coming with wiring system ground to clutch side radiator bracket.
stephenpen
I grounded to the right side rad mount. But why do people insist on only grounding to the battery. I've heard of intermittent heated visors and trail side break downs becuase of not grounding properly.
I dont wont my fuel solenoid not to turn on and burn down the machine.
I
I
