weirdo
- Dec 15, 2019
- Sydenham
- Nytro
hello. My issue (there’s lots). So new starter, new starter relay. The starter stays running intermittent not all the time but the only way can get it to stop is unhook the ground wire. I’m thinking I have a faulty relay its a aftermarket one?
YukonMP
- Dec 25, 2014
- Yukon Territory
You nailed it. Several members can attest from hard experience that its not worth the risk to try to save a buck on starter relays. You were on the ball to catch it, many don't.
Welcome to TY, otherwise known as Yamaha Heaven. The guys on here are really helpful.
weirdo
- Dec 15, 2019
- Sydenham
- Nytro
Thx you. I have learned tons of info from this forum. I put a light on the relay and it already paid off by telling me that the starter still has power. Off to the Yamaha dealer to bet OEM relay Monday. Thank you once again
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Count yourself lucky you caught it. Try pull starting a 4 stroke, it ain't easy. Been there, done that when my starter burned up because of a CCC starter relay.
Is it even possible to pull start a 4-stroke. How hard is it & what is the procedure. I have pull started my 2-strokes a few times.
Keith1962
- Mar 26, 2015
- Camillus, NY
- 2009 Nytro XTX,OFT Relocator, Excell exhaust, Curve Skis, Excell wheels, Dupont Slides. Star Suspension. Hygear Billet rear shock and spring spacer. Air Box Mod. Clutch mods, Polished tunnel. Custom GPS mount. BOP Skid Plate. RSI handwarmers.
I added an led light that will stay illuminated if the the relay sticks. Here's how to pull start a 4stroke
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
That's with a Phazer or MP though. Can't imagine a Nytro or, heaven forbid, an Apex. Might be possible with those. A stone cold engine though may be impossible as they take longer to crank.
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
Rockmeister is a vendor here (great support and great to deal with). He offers a LED kit as described. Also sells upgraded relays.Thx you. I have learned tons of info from this forum. I put a light on the relay and it already paid off by telling me that the starter still has power. Off to the Yamaha dealer to bet OEM relay Monday. Thank you once again
YAMAHEATER PRODUCTS
http://yamaheater.com/Products.php
I agree that TY4STROKE is worth its weight in gold!
Keith1962
- Mar 26, 2015
- Camillus, NY
You can pull start a Nytro or Apex . Strting an Apex is easier and a Nytro or over 3 cylinder yammies.
I made the starter warning light from on of these and some spare wire. Easy to do.
https://www.amazon.com/gp/product/B00I6ZP1FA/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
What does the wiring diagram look like? Wondering how you connect it up to the starter...You can pull start a Nytro or Apex . Strting an Apex is easier and a Nytro or over 3 cylinder yammies.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Just put the + side of the LED to the output to starter side of relay. Other side to any ground or battery -. Easy peasy.
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
Sweet, I found my next project... I had a starter stick on a 2012 A/C TZ1 previously, so I know what happens. Would definitely be nice to know beforehand.Just put the + side of the LED to the output to starter side of relay. Other side to any ground or battery -. Easy peasy.
- 10K
