lucky_7
You can get them from any Yami dealer. I have the white set and let me tell you...the work awesome!!!!
2008 Nytro RTX
Is there a place to order them online?lucky_7 said:You can get them from any Yami dealer. I have the white set and let me tell you...the work awesome!!!!
gormleyflyer2002
try some black magic marker
yamaouch08
Port Yamaha has them,heres the link:
http://www.portyamaha.com/eshopprod_cat ... _Defle.htm
marq
alxsno said:Hi, Does anyone know where i can get the extensions for the nytro's handgaurds that don't say nytro on them? I want to get a set for my phazer. Thanks
like these
Guys, he's looking for some that do not say Nytro... I'm also interested in finding out a part # if it exists.
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
These ones don't say Nytro on them but I'm not sure if they're exactly the same or not. http://www.portyamaha.com/eshopprod_cat ... eflect.htm
yep
Thanks, but your right , they arn't the same, they are the same as the skinz though.
2008 Nytro RTX
Do they actually work?
LJ 452
Yes the ones that say Nytro on them work. Will they keep you warm at minus 20, probably not but they were good and I definently did notice a difference.
As for getting some that don't say Nytro on them, what you could do is try using lighter fluid to remove the print. I know a friend did that to the visors in his truck to get the airbag warnings off. Worked good just took a while. Also if you do that you may not want to smoke or have any other flames around your sled for a few days.
