nightrunner06
- Nov 18, 2013
- madison, wi
- SideWinder LTX se
pro - x Axys switchback 800
2011 nytro mtx. I thought it attached to the engine towards the bottom. I cannot find it on the schematic.
so what is it? and where does it go?
Also, where does the ground cable from the battery attach to on the engine?
jonnytro
I never seen that part. I think it is for something else. An the ground goes o the front motor mount. Top bolt.An if ur sitting on the sled it would be right side
nightrunner06
- Nov 18, 2013
- madison, wi
- SideWinder LTX se
ok thanks, I thought that it may be for something else, but i wanted to make sure....
nitris223
- Nov 18, 2012
- Yorkton Saskatchewan
- Yamaha Nytro MTX
That part fits the nytro. There are two of them, one on each side. The round part fits onto the sub frame and the angled piece fits flush with the plastic. How do I explain where they go. Basically they are behind the lower a arm mount. They can get pushed out of the way when you put the lower plastic on. There is a round notch cut into the plastic that fills in around the a arms. If you look at a 2011 mtx under shroud. Part # 31 is the plastic piece I am referring to . There is a push in tap or rivet that holds the piece onto the sub frame. Directly to the rear of that push pin is where that rubber piece goes. If you can't find it I will see if I can get a picture of it.
nightrunner06
- Nov 18, 2013
- madison, wi
- SideWinder LTX se
Ok thanks! I will try to find it this morning!
raginyamaha
- Jan 11, 2007
- Waterford, wi
- 2013 xtx
Looks like the swaybar hole filler for an mtx. take the swaybar out and those go in the holes in the paneling to keep the snow out...
nitris223
- Nov 18, 2012
- Yamaha Nytro MTX
Sway bar plug. There ya go. I knew it was there for a reason and what it was but couldn't put a name to it. Tried looking on a parts diagram last night and I couldn't find it anywhere. Could be under something stupid on the parts diagram. Wouldn't be the first thing that is not where you would think it would be.
nightrunner06
- Nov 18, 2013
- madison, wi
- SideWinder LTX se
that's it, thanks guys!
